Previous Thread This topic has been viewed 7309 times and has 13 replies Next Thread
zymme
Sverige
problem with placing / mergering objects
Im trying to put a sink in a cabninet and the countertop.
But the sink is filled with the countertop when I do it
I also tried with out the countertop but its same problem.
I guess somehow its due to its different objects and I need to priortize the sink to be sunken into the cabinet/countertop?
Can any guide me how to to proceed?
thanks in advance!
See 2 examples below,
https://pasteboard.co/JI03WvS.png
https://pasteboard.co/JI073AA.png
[Jan 4, 2021, 12:26:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: problem with placing / mergering objects
you could try checking this project file:
Counter-tut.sh3d
Create a level @88 cm ( or at whatever height your preferred counter might be) :
Draw your counter with the Create rooms - tool
Modify your sink:
Configuring an object as a staircase, it will always make a cut-out in any floor or ceiling.
Study the project file. There are several ways to do this.
Cecilia
[Jan 4, 2021, 5:36:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zymme
Sverige
Hej!
Thanks for you answer, its better, but still not good.
its the counter which is the problem.
any good tip? :)
[Jan 5, 2021, 9:27:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you don't explain what your problem is, you won't get many tips.
If you want your countertop thicker/thinner, just change the floor height.
[Jan 6, 2021, 11:00:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zymme
Sverige
Hej!
any good tip? :)
sorry the image was not attached correcly I can see..
see link below to understand my problem with the filled sink :)
https://pasteboard.co/JIhKXu7.png
[Jan 6, 2021, 4:53:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SH3D does not automatically remove, or make invisible, intersecting parts. Only exception are stairs inserted into floors/ceilings. So, remove the top of the cabinet before inserting the sink,eg by making topless cabinets, or making the top invisible using the Modify Furniture dialogue.
[Jan 6, 2021, 6:53:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zyzer
Hi everyone,
New user here also. Saw this thread and this is exactly what i am looking for as well.
I opened the project that Ceciliabr posted but i simply cannot that replicate to my project. I can do the countertop as level 2, but then i add the sink as a staircase and it doesnt cut through the countertop. Tried copying and pasting invisible box to my project but it does nothing. What am i doing wrong?
And in general, how do you make kitchens in SH3D? Do you make countertop as level 2 floor and then add counters on the level 1 floor? How do i make proper kitchen?
[Jan 15, 2021, 6:08:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi. Take a look at THIS file, it may help.
[Jan 16, 2021, 11:28:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zyzer
Thanks! It helped, i finally managed to create a half decent kitchen.
But i still don't understand how can i create or modify my own countertop with a customizable hole in it.
Please, is there a detailed tutorial somwehere? Would very much appreciate it.
[Jan 16, 2021, 10:09:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
From the image you posted it looks to me that the counter is ok, but the cabinet is a solid block and that it what can be seen in the sink. to check this, change the colour of the cabinet.
then look at option 3 in the file i shared
[Jan 17, 2021, 9:22:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
