Total posts in this thread: 2
Previous Thread This topic has been viewed 3975 times and has 1 reply Next Thread
vmq
US
Modify level - what elevation, floor thickness and height affect
After adding levels to my current project and loosing the vaulted ceiling that I had added for the living room area I started searching the User's Guide, the in program help and Google for a concise summary how elevation, floor thickness and height really work. After playing with a test drawing I found the following additional information:
  • Elevation is the level the furniture objects will be placed and floor surfaces of rooms (if enabled) will be shown. (That one is obvious.)
  • Floor thickness indicates how thick the floor is. This thickness reaches below the elevation and is seen from lower levels with the color or texture that is used for the floor of the corresponding room when looking up from lower floors. A room floor effectively becomes a polygon extruded below the surface with the given thickness. Walls from higher levels also reach below the elevation of their corresponding level with the assigned colors or textures visible.
  • Height is used to draw ceilings at this height for rooms at the current level, except at the topmost level, when the wall-height is used to calculate the ceiling height for rooms that are nearby. The ceiling is always a polygon with zero thickness.
Did I get that right, or am I missing other effects?
[Jan 10, 2021, 8:35:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Modify level - what elevation, floor thickness and height affect
Your summary is correct, except for the following comment:
This thickness [...] is seen from lower levels with the color or texture that is used for the floor of the corresponding room when looking up from lower floors.
The color or texture seen from lower levels is rather the color or texture set for the ceiling of the rooms at the lower level, as you explain it in the 3rd point. Actually, you comment is true only if there's no room at the lower level.
See also the Managing the ceiling at first floor section in this tip.
[Jan 13, 2021, 12:27:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
