Previous Thread This topic has been viewed 14964 times and has 20 replies Next Thread
snmavronis
3D Ceiling Fan (Lighting)
I'm modeling my house and although there is a similar fan design in SH3D it does not have a light option built-in. I can't seem to add lights around it without making the globe look black in areas. Is there a free model compatible with SH3D of a ceiling fan similar to this that lights? If not a globe light fan, a separate cluster of lights might be acceptable but I prefer a 4-bladed fan. I've been looking all over the place.
Or any tips for properly lighting the stock SH3D fan without looking fake would be appreciated. I wish it's ball was translucent so I could put a single light inside.
[Jan 18, 2021, 3:35:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D Ceiling Fan (Lighting)
Something like this
fan and lamps are from sh3d library
File here
[Jan 18, 2021, 9:20:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Quick and dirty solution:
- make ceiling fan ball material (CeilingFan6900_4_4) invisible
- replace ball with transparent ball (same place and dimensions)
Transparent balls can be found from SketcUp 3D Warehouse and they seem to be problematic but here are one result:
My test file here:
Mike was quicker but I send this any way..
Seppo
[Jan 18, 2021, 9:26:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Thank you guys! I'll check this out. :)
[Jan 18, 2021, 9:43:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Hmm... Can't get rid of that black hole chrome ball effect and any brighter than 25% washes out the fan blades. After studying what you guys did, I simply made the fan's light globe invisible and added the SH3D pendant hanging ball with it's ceiling cable invisible. I haven't tried different renderers yet. What's the best to use?
This is to visualize our kitchen remodel to be scheduled soon, but I'm working on modeling my whole townhouse.
[Jan 19, 2021, 2:07:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SeppoV12
Finland
Yafaray is my favourite render, usually it handles lighting better but is also slower in some cases.
I still have problems with that same 'black hole chrome ball effect', I try something new.
[Jan 19, 2021, 3:27:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As explained in this thread, you could try to set illum to 0 for the material CeilingFan6900_4_4 in the MTL file of the fan that you use.
[Jan 19, 2021, 3:51:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I read parts of that thread about using illum=0 although with an exported ball pendant lamp and Kd 1.0 1.0 1.0 for white in the MTL. I get this effect at least with a white-ish light ball in the "original" pendant ball lamp. I got this result but now that I'm re-reading Puybaret's suggesting again I should go back and export the fan model itself! What I did was easy but too many steps and no glow effect. Let me test this again your way since I misread it slightly. ;)
[Jan 20, 2021, 11:21:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Oh before I forget how to I set the Global illumination path? Is that a separate plug-in?
[Jan 20, 2021, 11:22:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Editing the MTL file of the exported ceiling fan directly gave me this undesired result - only downward lighting. I'm not sure what the other default parameters are in the CeilingFan6900_4_4 section:
newmtl CeilingFan6900_4_4
illum 0
Ka 1.0 0.964706 0.815686
Kd 1.0 1.0 1.0
Ks 1.0 1.0 1.0
Ns 128.0
[Jan 21, 2021, 12:06:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
