Previous Thread This topic has been viewed 3254 times and has 2 replies Next Thread
snmavronis
Basement Level (Hole In Ground)
If you had your main floor ( level 1) at elevation 0 modeling your real home but in fact in reality it’s several feet above outside ground level, how do you change that so the basement (level 0) is partially above ground level? I’ve already created my entire first floor with furnishings and everything, being new to SH3D. Can I reset the first floor elevation without screwing the vertical location of every object? Actually I’d like to create the exterior too and my front and backyards which slope away from my house. I didn’t realize a basement would carve a hole in the ground. I wish the house was floating in virtual space and then I could create the landscape without a false ground effect, I.e., basement level hole.
[Jan 27, 2021, 7:58:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Re: Basement Level (Hole In Ground)
Or maybe I think outside the box and literally create a landscape hole around the basement? It would in effect be a "landscape" room?
[Jan 27, 2021, 8:05:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe this tip, and this one, will help you?
[Jan 28, 2021, 11:56:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
