Total posts in this thread: 4
Previous Thread This topic has been viewed 4780 times and has 3 replies Next Thread
HABITALIA
España
THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
HELLO:
THE OTHER DAY I CLOSED THE APPLICATION AND WHEN I OPENED IT AGAIN, IT HAS REPLACED ALL THE OBJECTS WITH FRAMES WITH AN "X" AND IN THE 3D VIEW EVERYTHING IS LIKE GEOMETRIC FIGURES. ANYONE KNOWS THE REASON? THANKS A LOT
[Feb 25, 2021, 7:01:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
Did you move the design to another directory? Update your computer? Changed the directory structure?
Aside... which OS do you use, which version of SH3D?
[Feb 25, 2021, 9:13:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HABITALIA
España
Good morning:
I did nothing. I even open another file that I use from the same work and it comes out perfectly. The system is windows 10. It only happens to me in this file. Thanks
[Feb 25, 2021, 10:22:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Your file might be damaged. Sent it to me, I'll try to understand the problem and fix it if possible.
[Feb 25, 2021, 10:49:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
