Total posts in this thread: 6
Previous Thread This topic has been viewed 3239 times and has 5 replies Next Thread
noise694
Portugal
How can i remove text from my house?
Hi, im new at sweet home 3d, i added a text to my house and now i can´t remove it. Can someone help pls?
[Mar 1, 2021, 3:35:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How can i remove text from my house?
Did you try to click on it to select it and choose Edit > Delete menu item?
[Mar 2, 2021, 9:47:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rickster55
Canada
I`m having the same problem. I tried clicking on the text, but nothing happens. It`s like there`s no object there. I even tried `Select All` which selects all the object, but no text.
[May 16, 2024, 11:42:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe it’s the name of a piece of furniture in which case you should unselect Display name in plan check box in its modification dialog box.
[May 17, 2024, 8:23:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
It sounds stupid if the text is in a locked level, if you use them
[Jan 17, 2025, 7:17:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Text is always on the base plan level. If the base plan is locked, the text cannot be selected. Unlock the base plan and then it is possible to select and delete the text. If you opened the furniture properties by double-clicking on the object, deselect the enabled option to show the name of the object.
[Jan 21, 2025, 12:37:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
