Re: Transparent floor
Here's my suggestion: - Create a new home - Choose Plan > Add level menu item - Select room creation tool and draw the shape you want - Choose 3D view > Modify 3D view menu item and select the transparency level you want with Walls transparency slider - Choose 3D view > Export to OBJ format and confirm the option Export selection when prompted - Import in your main home the exported OBJ file with Furniture > Import furniture menu item
Finland
Hi, thanks for the hint, yes this solution works; there is any additional possibility just to assign to the floor the glass material similarly to the windows object? Thanks
Excelent! Worked perfectly and saved me an hours trying to get it to work in blender.
Who said you can't do it. I don't listen to Who anymore.
Personally I find it easier to edit the exported object and add a d value (transparency) to the material I want to be transparent. In most cases you only want one part to have transparency and with the manual edit that's just as easy.
Maybe even simpler solution: Create a transparent png and use it as an imported texture in Modify 3D View / Ground.
Simpler? For me setting the d parameter is just as simple. With a texture image you are stuck with that image. Using the d property in the mtl file leaves you the option to change colors for semi-transparent objects like tinted windows. Besides that, a texture increases the imported object size with the size of the texture. It also increases the rendering time for a photo.
For simple window glass (a pane WxHxD 100x100x0.5) Glass.obj:
mtllib Glass.mtl g glass_1 usemtl Glass v -50.0 250.0 -0.250002 v 50.0 250.0 -0.250002 v 50.0 250.0 0.249998 v -50.0 250.0 0.249998 v -50.0 350.0 -0.24999799 v -50.0 350.0 0.250002 v 50.0 350.0 0.250002 v 50.0 350.0 -0.24999799 vt 0.0 0.0 0 vt 1.0 0.0 0 vt 1.0 1.0 0 vt 0.0 1.0 0 vn 0.0 -1.0 0.0 vn 0.0 1.0 0.0 vn -1.0 0.0 0.0 vn 1.0 0.0 0.0 vn 0.0 0.0 -1.0 vn 0.0 0.0 1.0 f 1/1/1 2/2/1 3/3/1 f 1/1/1 3/3/1 4/4/1 f 5/4/2 6/1/2 7/2/2 f 5/4/2 7/2/2 8/3/2 f 1/1/3 4/2/3 6/3/3 f 1/1/3 6/3/3 5/4/3 f 2/2/4 8/3/4 7/4/4 f 2/2/4 7/4/4 3/1/4 f 1/2/5 5/3/5 8/4/5 f 1/2/5 8/4/5 2/1/5 f 3/2/6 7/3/6 6/4/6 f 3/2/6 6/4/6 4/1/6
Glass.mtl:
newmtl Glass illum 2 Ka 1.0 1.0 1.0 Kd 1.0 1.0 1.0 Ks 0.0 0.0 0.0 Ns 1.0 Ni 1.45 d 0.4
You can import the glass object and resize it to any format you need.
A nice trick: import the glass as a staircase and you can can insert a partial glass floor. Rotate the pane horizontal and make the depth the same as the floor thickness. Elevate the glass in the room below to the wall height. Done, a nice glass 'hole' in the floor.
[Edit 1 times,
last edit by Keet at May 7, 2024, 1:06:21 PM]
