Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 4714 times and has 14 replies Next Thread
mimc911
New addition to my home can I submit to an engineer
I used sweet home 3D to do the draft drawing of an extension that will be added to my current house
I completed six different drawings one of them include the main floor plan, east side view, west side view, piling Map, Cross section view, location of the addition on the current lot survey
All these drawings are done with the exact dimensions and the dimensions are included in the drawings
Can I submit it is drawings to an engineer to review and certify?
If there is any way to
Print the finalize the draft drawing using sweet home 3-D before I submit them to the engineer?
Is there is any way I can post my drawings to get your feedback
Thank you for your help
Are you greatly appreciated
Thank you
[May 1, 2021, 10:49:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: New addition to my home can I submit to an engineer
1 - Printing
Of course you can print. Use File -> Page Setup then File Print or Print to PDF (in case you need larger than A4/Letter size paper).
2 - Submit to engineer
Of course you can.
NOTE: I assume you have to comply with local regulations. This is not the forum for instructions of that kind...
3 - Check out this post on how to share your design.
[May 2, 2021, 10:53:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
Thanks for your reply
I am familiar with the codes
I just want to make sure that the draft drawing has the basic features and the measurements that are usually required for the engineer to make decision as to certify or not
Can I attach a file for you to have a look at?
Thanks
[May 2, 2021, 7:33:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Feel free to share your file for someone knowledgeable to shed some light on your design.
[May 2, 2021, 7:42:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
I will share as soon as I am done with it
Thanks for your reply appreciated
[May 3, 2021, 3:14:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
here is the mail floor plan file
https://www.mediafire.com/file/8bfnykefsaazz1...an_updated_May_3.pdf/file
I will do the east side view, west side view, cross section, piling map after I get feedback on this file
I added all the measurements myself, is there any option to have the measurements autopopulate when you decide to print?
Thanks again
[May 3, 2021, 7:57:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
https://www.mediafire.com/file/rowvc7hnv2lrwv...May_3%25282%2529.pdf/file
https://www.mediafire.com/folder/glxc37aqugb1...34,783p3vrhc9i4a99/shared
[May 3, 2021, 8:19:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Use the AutoDimensioning plugin?
[May 3, 2021, 11:47:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
Thanks I just downloaded the plugin and installed it
[May 4, 2021, 12:07:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mimc911
Did anyone got a chance to look at my file?
[May 4, 2021, 12:38:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
