Total posts in this thread: 4
Previous Thread This topic has been viewed 2228 times and has 3 replies Next Thread
madduck
Adding lintols (lintels) between two walls
I am trying to add a lintel/lintol to a wall that's been removed, i.e. there is now a structural beam at the top (height 50cm, elevation 200cm), which is considered part of and integrates perfectly with the wall.
I cannot create a wall that has an elevation. This post this post suggests I add another level and change its elevation to 200cm, then add a wall of 50cm, but this seems like a pretty bad hack.
Similarly, using a "miscellaneous box", as suggested here, but that is also a hack, and the box is displayed in a different shade than the wall (despite the colours being exactly the same).
An alternative might be a "frameless door frame", but no such object seems to exist.
How is one supposed to do this properly?
[May 18, 2021, 6:53:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
Re: Adding lintols (lintels) between two walls
Insert a door frame inside the wall, edit the dimensions, make "white" materiel invisible
[May 19, 2021, 1:41:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
Just to be clear, SH3d is an extremely powerful software, but some mode "complex" things requires a bit of imagination and a lot of so called "hacks".
You must be ready to "hack" your project if you want nicer results.
[May 19, 2021, 1:44:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
here is a video of example
https://screenrec.com/share/VtKHMNAf02
sorry it seems i had problems with numpad LOLL
[May 19, 2021, 1:48:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
