Previous Thread This topic has been viewed 1945 times and has 2 replies Next Thread
zuize411
lostanglest
Adding a crawl space afterwards
Hi! Thanks for this great program!
I am trying to add a crawl space after I have designed the other levels (my mistake). So I added a new level with some walls, set elevation to 0 and added the height of the crawl space as elevation value to the other levels (3 levels). All elements, furniture etc. are now correctly elevated but the walls are not elevated. The walls of the ground floor are e.g. still on the ground (and therefore obscuring the crawl space). They should be on top of the crawl space. I have done houses with basements before (negative elevation) but then I have always started with the lowest level. Now I am trying to add it afterwards. What am I doing wrong?
[Jun 8, 2021, 11:16:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Adding a crawl space afterwards
Several possibilities, hard to say without seeing your design.
Can you share it?
[Jun 9, 2021, 6:00:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
digitaltrails
New Zealand
Perhaps you could try and create a new model with the right levels and then cut and paste all the content of the old model into the correct levels of the new model.
[Jun 10, 2021, 12:33:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
