ManuMan79
Re: Mac OS X Version 6.6.5 (MacApp Store) doesn't start
On Macbook M1 Monterey(bêta 12.0 (21A5506j) : Do'nt start : From Terminal Last login: Wed Sep 22 15:46:38 on ttys000 You have mail. Emmanuel@MBP13-M1 ~ % /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D ; exit; CoreSVG has logged an error. Set environment variabe "CORESVG_VERBOSE" to learn more. WARNING: An illegal reflective access operation has occurred WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/Applications/Sweet%20Home%203D.app/Contents/app/j3dcore.jar) to method sun.awt.AppContext.getAppContext() WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations WARNING: All illegal access operations will be denied in a future release # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x0000000112321b44, pid=60551, tid=9475 # # JRE version: OpenJDK Runtime Environment Zulu15.29+15-CA (15.0.2+7) (build 15.0.2+7) # Java VM: OpenJDK 64-Bit Server VM Zulu15.29+15-CA (15.0.2+7, mixed mode, tiered, compressed oops, g1 gc, bsd-aarch64) # Problematic frame: # J 1245 c2 jdk.internal.jimage.ImageStringsReader.charsFromByteBufferLength(Ljava/nio/ByteBuffer;)I java.base@15.0.2 (47 bytes) @ 0x0000000112321b44 [0x0000000112321ac0+0x0000000000000084] # # No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /Users/Emmanuel/hs_err_pid60551.log Compiled method (c1) 2256 218 3 java.nio.DirectByteBuffer::<init> (55 bytes) total in heap [0x000000010add3a10,0x000000010add41a8] = 1944 relocation [0x000000010add3b68,0x000000010add3bd8] = 112 main code [0x000000010add3c00,0x000000010add3fc0] = 960 stub code [0x000000010add3fc0,0x000000010add4078] = 184 metadata [0x000000010add4078,0x000000010add40a0] = 40 scopes data [0x000000010add40a0,0x000000010add4120] = 128 scopes pcs [0x000000010add4120,0x000000010add4190] = 112 dependencies [0x000000010add4190,0x000000010add4198] = 8 nul chk table [0x000000010add4198,0x000000010add41a8] = 16 # # If you would like to submit a bug report, please visit: # http://www.azulsystems.com/support/ # zsh: abort /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D Saving session... ...copying shared history... ...saving history...truncating history files... ...completed. Deleting expired sessions... 6 completed.
[Opération terminée]
[Sep 22, 2021, 5:39:37 PM]
[Link]
