Total posts in this thread: 6
Previous Thread This topic has been viewed 7872 times and has 5 replies Next Thread
DerekvG
Belgium
Wooden walls
Hello,
I'm looking for a library of walls floors and roofs in wood
i mean a wooden frame, plywood panel exterior, damp/moistures screen, plaster sheating, beams, posts, columns, joists, trusses, rafters, girders etc
Especially the wood-frame walls are important, such that i don't have to build every frame wall with boxes representing beams
[Jul 5, 2021, 5:00:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
reddy.shyam
Re: Wooden walls
Hi Derekvg,
How about walls with wooden texture?
[Jul 6, 2021, 11:09:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DerekvG
Belgium
Re: Wooden walls
Hi Reddy
Thanks for your suggestion
That was not the objective of my question, I might be asking too much level of detail and the when i speak of a wooden-frame wall it looks somewhat like this example of wooden wall
I could build the frames with boxes then add the panelling and then put a wall panel in my design, however that would be like furniture and the wall panel would not react like a wall so that you can put doors and windows in it.
[Jul 6, 2021, 6:01:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wooden walls
You could add many thin walls side by side, but I don't think it's worth it.
[Jul 7, 2021, 2:23:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DerekvG
Belgium
Re: Wooden walls
Thanks,
I understand , I'll use plain walls of the correct total width with woodpanel texture
I was asking for too much detail I will need to design my walls otherwise
[Jul 7, 2021, 4:54:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lspatricio
Re: Wooden walls
In making wall frames etc, I use the dimensional lumber library from this blog post
http://www.sweethome3d.com/blog/2017/12/08/ad...ntributors_libraries.html
Author has standard sized lumber and frames and plywoods etc.
Moreover there's plumbing items library among others.
Maybe you could check it out and see if you find something helpful to you.
[Jul 12, 2021, 3:12:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
