Inserting steps and staircase
Hit, I have a house with two storeys and I am attempting to enter a staircase to connect the two.
My problem: The objects available do not suit my purpose, that is I can't modify them to fit in to the space between the floors available.
Q1: How can I build a staircase made up of steps which turn approx. 90° two thirds of the way down with a bannister on the left wall going down? The steps are between two walls.
Q2: How can the stair objects available in 3D be adapted to suit the position and the shape of the space available at the ground floor and where the stairs end, at the 1st floor?
Re: Inserting steps and staircase
Q2 - You can change the size and colours of staircases, or make parts invisible. You can also flip (mirror) the model. You can't change the model itself, e.g. add extra steps to a staircase. Q1 - You can build your own model using boxes, triangles, etc. Then export it, import it and mark it as a staircase during importation. Read the User Guide.
There is Art of Illusion recommended on this site. Plus a number of free softwares listed in this article: https://all3dp.com/1/free-3d-modeling-software-free-3d-design-software-3d-cad/ I tried a number of them, some doesn't work on my computer (low end Intel graphics card), some are broken (bad registration process), I was a bit successful with Art of Illusion (after deactivating OpenGL), DesignSpark Mechanical (made a primitive cheminey with it), I plan to try Wings 3D.
US
I hate the learning curve of most 3D programs, as they have a lot of features (and the accompanying GUI) that i dont use. Blender is the worst of the free ones, but AoI is the easiest. It's still a little hard to get used to, but it has a simple interface (altho no support). Still, AoI is tried and true and works for the most part at creating complex architectural pieces for your SH3D home. The texturing and material use is hit or miss and takes a lot of trial and error. My advice is add flat pieces -- don't extrude or manipulate primitives, so the textures don't blur or streak when importing to SH3D.
Bonjour: pour un escalier personnalisé il y a plusieurs techniques et astuces
commence par t'entrainer un peu sur un plan vierge
1) utiliser des morceaux d'escalier existant double cliquer dessus cliquer sur modifier matériaux sélectionner une partie 'elle clignote' elle peut être rendue invisible avec 2 ou 3 tu peut faire de l'à peu près
2) avec des objets 'notamment boite ou des étagères' en redimensionnant et ajuster l'élévation création d'escalier simple
3) la fonction grouper une fois ta marche et contre marche faite tu sélectionne l'ensemble clic droit et grouper cela te fait une marche complète tu peux utiliser du copier coller et ajuster l'élévation
(note si tu clique sur un groupe attend 2 secondes et de nouveau clic droit tu peux modifier ou supprimer ce seul objet du groupe
pour aller plus loin des plug-in sur le site Sweet-home sont disponible 3) conception complète les outils disponible
pour avoir de l'aide sur les plug-in en français pour le MAC il faut ouvrir le site sweet-home avec google chrome si on utilise safari on a pas la traduction dans la page faire un clic droit choisir traduire en français
- le plug-in générer forme 3D outil/ générer forme 3D tu peux te créer une marche de ta forme
- avec le plug in multiplier tu peut multiplier la 1ère marche en la décalant et la relevant tu sélectionne l'objet ou groupe menu outil / multiplier ton nombre de marche décalage Z = hauteur décalage x ou Y longueur marche
ensuite tu as mème les rotations mais je n'ai pas utilisé
petite astuce le groupe de marche créé ne comprend pas la marche qui à été dupliquée pour simplifier les ajustages déplacer la marche de base et descendre l"élévation cela donnera un escalier d'une pièce
pour modifier 1 marche ou en enlever une (ex: perron ) cliquer sur l"escalier attendre 2 secondes cliquer sur la partie à modifier
d'autres plug in permettent de sauvegarder ses propres meubles... à découvrir
mac mini 2020 plan technique plus que déco
