Total posts in this thread: 5
Previous Thread This topic has been viewed 1879 times and has 4 replies Next Thread
TM007
Finland
An arch roof
Hello.
Newbie asks that how I do an arch roof to a room? Like cave ceiling? We have some 3m width room and according to test (as a normal wall) arch extent is 118 degrees. In other words the arc is bent some 80 cm. Rgs, TM007
[Sep 22, 2021, 7:58:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: An arch roof
- Draw a wall of the length needed (3 mtr)
- Use Modify walls - Arc extent and set it to 118 degrees
- Apply texture(s) on inside and/or outside (rotate 90 degrees if needed)
- Export selection
- Import and rotate 90 degrees
[Sep 22, 2021, 3:02:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TM007
Finland
Re: An arch roof
Hello hansmex. Thanks about guiding. I followed maybe wrong Your instructions because I couldn't "flip" the arch to top of the room. I try harder. Anyway nice to know that it is easy to make own library elements! Nice feature.
[Sep 22, 2021, 4:12:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TM007
Finland
Re: An arch roof
This is missing in Mod walls : "(rotate 90 degrees if needed)
[Sep 22, 2021, 4:25:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: An arch roof
Read the user guide on how to export part of a model, and in how to import and rotate it.
[Sep 22, 2021, 5:17:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
