Total posts in this thread: 339
Posts: 339   Pages: 34   [ 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 3031048 times and has 338 replies Next Thread
dorin
Romania
Generate roof plugin
In the series of YAUP: GenerateRoof plugin v1.0 alpha
!!! WARNING !!!
  • Fail on more than 90% of cases
  • Not all texture are correct rendered
Q:"Why you published like this?"
A:"It's a path trout jungle. Someone else could make a highway from this"
How I think to use:
  • Select a room (manually made or trout Autodimensioning))
  • Tools -> Generate roof... bla.. bla..
  • Set roof faces angle -> OK (optionally check inner polygons)
  • On preview click OK
Result something like this:
Now you have to set textures and texture angle:
Finally (if You have lack):
Don't forget!!!
It's an alpha stage AND
I'm not a programmer!
PS This is the test file .
[Edit 1 times, last edit by dorin at Oct 3, 2021, 3:43:11 PM]
[Oct 3, 2021, 2:51:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Generate roof plugin
Your plugin works on the test-file, and also on a simple square house. That's a start.
The problem with the textures is not new. Maybe Puybaret will solve it some day.
Thank you for your hard work, I'm sure it will get better :-)
[Oct 3, 2021, 4:04:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Thanks Hans!
As usual you are tolerant of me!
I hope so also but not in my life time.
I think it's a wrong way (approach) or at least too complicated.
There are a lot of math which are over my helmet.
It's hard for a "One man show" and I need help. I haven't received any help so far and I don't think I will.
It is difficult to consult only with yourself.
I think to try with 3D plane approach but is not more simple.
My plan is to try another challenge: cross section plan.
We will see!!!
Thanks again for moral support!
[Oct 3, 2021, 9:16:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Nice first version. Congratulations! smile
As inner polygons seem to be generally accurate, I guess you are on the good path to fix most issues.
[Oct 5, 2021, 12:21:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Thanks Emmanuel!
Of course, are made with your code from PlanControler.
The part responsible with roof computation (partially mine, partially stolen) don't work as expected.
I will let this path for other volunteers(if any).
As I've already say, I will try another approach (if the life time hope permit).
I've study about 3D Plane equation for few weeks and appear is not so complicated as seems at first view.
For this version I've work in frog, with out a plan and try, test and fail without a clear target.
The main path remain the same:
roof projection -> compute roof -> create shape -> add to Home Plane.
Now I'll try to be more clearly organized. I've start to make a logical diagram for this plugin like in '70+ years. I will put it here when I have first version.
[Oct 5, 2021, 10:20:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
applause Re: Generate roof plugin
The reason for the texture error is that the texture coordinates are calculated incorrectly
-----obj example--------
mtllib Exemple9.mtl
g 1_1_1_1_1_1
usemtl default
v 4496.651 683.83997 1944.5
v 4080.21 267.83997 2360.941
v 5405.8 267.83997 2360.941
v 4739.619 582.83997 2045.1409
v 5090.0 582.83997 2045.1409
vn 0.0072383927 0.71531975 0.6987598
vn -0 0.70748127 0.7067321
vn 0.0048255385 0.7128935 0.7012557
vn 0.0072383634 0.7155777 0.6984956
vn -0 0.708003 0.7062094
vt 2.572153 3.0108545 0
vt 4.0783777 0.0 0
vt 4.0783777 4.7945237 0
vt 2.9361613 3.52434 0
vt 2.9361613 4.7916303 0
f 1/1/1 2/2/2 3/3/3
f 4/4/4 1/1/1 3/3/3
f 4/4/4 3/3/3 5/5/5
5 polygon vertices V, corresponding to 5 VT
Bring 5 V's into 3D space,The apex of a partially sloping roof can be seen.
But it is not easy to calculate the correct texture coordinate value, and I don't know
There are such UV tools in other modeling software
[Oct 10, 2021, 10:50:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pelmenik
New Zealand
like this plug-in.
I tried it with a 25deg hipped roof for an L shaped house and it worked well. To set percentage and angle for a corrugated texture for each roof section was quick. Now I will attach the flashings and other details.
My usual way to make a roof is by deciding the roof angles, calculate walls for each roof section, .obj, and then lay them into each other at the decided angles and then attach flashings and any other details.
[Oct 29, 2021, 7:12:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
clown In the series of YAUP: Generate Roof plugin v.1.0
Don't expect too much!
As I promise I've try another approach: planes intersections.
There is advantages and disadvantages.
Anyway few words and pictures for this version:
It work for few simple roofs: rectangle and shape L, T, S, F(as described here).
Don't work as expected on complex shapes like E or round.
The angle could be adjusted before add roof to home plane.
The blue edges could be made invisible when You set texture.
BUGS:
-Sometimes make SH3D unresponsive;
-Texture coordinate are wrong on north faces;
-The interior face of roof are transparent.
Also on SurceForge .
[Dec 25, 2021, 11:33:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Nice gift for Christmas! Thank you Dorin smile
[Dec 25, 2021, 11:47:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sad Re: Generate roof plugin
Thank you for this first try.
After downloading and installing this plug-in, it works one time (for the garages) and not twice (for the main house) !
After done many tries, I think that I found first bug... biggrin
Why ?
Good luck and HNY !
sad
[Dec 26, 2021, 8:47:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
