PT
Re: Maybe... 3D rendering preview problem
Hello and thank you for the support,
I'm showing below the prints of the problem.
Other info which might be helpful: I'm using the version Sweet Home 6.3 / Java 1.8.0_202 32bit and I have extra installed for Furniture and Textures editor purposes: -Java Version 8 update 281 (build 1.8.0_281-b09)
(the built-in java in the Program didn't work for me)
I believe the extra Java version 8 is not the problem because I did a rollback in the Windows 7 restore points to before the Java installation and the problem remained.
The ability to compute top view images depends on whether your computer is able to handle offscreen images or not, but I didn't know that it could vary overtime! As you use the 32 bit version, maybe you could try the DirectX version as explained here.
