Total posts in this thread: 63
Posts: 63   Pages: 7   [ Previous Page | 1 2 3 4 5 6 7 ]
Previous Thread This topic has been viewed 83509 times and has 62 replies Next Thread
vlycop
Re: Wirings plugin
Hello
I am trying this plugin for the first time, i'm not a huge user of sweethome 3D so maybe i made a mistake, but i can't seam to have the wire go to a negative level ?
Like from the ground floor to the frist floor, no issue, but going down to the "basement" it won't do it ?
Can someone please double check i'm not just bad at it please :D
[Feb 8, 2024, 10:21:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: Wirings plugin
By default the 3D view shows only objects belonging to levels from the ground to the selected one. To show levels at negative elevations you must select them, so levels above (and objects belonging to them) aren't displayed.
If you start drawing the wiring at level 1, and then select the basement, then the wiring won't be shown, because it belongs to an higher level.
The workaround is to change the 3D view settings so that it shows all levels: right click the 3D view and select "Show all levels", or press CTRL+ALT+A.
[Feb 11, 2024, 11:14:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
otadmin
Re: Wirings plugin
Thanks for this plugin. Have to learn how to use it.
My problem: I have drawn a line and want to change it higher up the wall. In the 3D-view the points can not be selected only in the 2D-plan. How can I change the elevation of a line or its points?
[Mar 28, 2024, 8:37:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
