Italy
Re: Wirings plugin
Hi 241177793, there isn't any wrong with your installation, you just found a bug in the plugin. It will be fixed by tomorrow. You don't find the 3rd coordinate because wiring nodes are just a side effect, the real wiring data is stored in custom properties named "it.ld.sh3dplugins.wirings.Wiring@unique_id".
Colombia
Re: Wirings plugin
Good morning Daniels118, is there any way to make it possible to edit the measurement lines from a pop-up window or in the 3d plane itself? Editing the line from the 2d plane is very difficult, especially if the line made has been crooked.
Italy
Re: Wirings plugin
@IvanDiaz There is a bug that prevents selecting wirings from the plan view, it will be fixed in the next release and I will also add a method to edit the wiring properties directly from the 3D view.
Re: Wirings plugin
After loading the wiring plugin Sweet home 3d will not launch. It says I must load the Pan plugin first but I can't launch the program now! I've tried to delete everything and reinstall several time, no luck!.
Re: Wirings plugin
If you are on Windows: Go to "C:\[USER]\eTeks\Sweet Home 3D" with your file manager. There should be a folder for the plugins. Delete the wirings sh3p file and you can start Sweet Home 3D again. Now first install the Pan3DView plugin before you reinstall the wiring plugin. I suggest that you install the Plugin Manager as mentioned in the post right before yours and use that to install other plugins.
On Linux the plugin directory is /home/[USER]/.eteks/sweethome3d/plugins. That is a hidden directory so don't forget to switch your view in the file manager to view hidden files. (Notice the . before 'eteks', hidden files/directories start with a point on Linux.)
On Apple? I have no idea.
[Edit 1 times,
last edit by Keet at Nov 16, 2023, 8:42:05 PM]
Re: Wirings plugin
If you use Windows, the plugins folder is in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D, and not in C:\user\eTeks\Sweet Home 3D. If you don't see AppData folder, try suggestions here.
Re: Wirings plugin
I better refrain from remarks concerning Windows in the future The wrong path I mentioned came from another forum post but apparently MS has changed them over the years. I haven't used Windows since XP so I had no idea about those changes.
