Total posts in this thread: 2
Previous Thread This topic has been viewed 1344 times and has 1 reply Next Thread
sjskhalsa
United States
inconsistent results when rotating 2 objects
I followed the tip for creating an inclined roof with windows, and used the rotate about horizontal axis after importing the wall to set the angle. When I add a beam, drawn as a box, and rotate it about the same axis by the same angle it does not match the angle of the roof! I have to add 10 degrees to the rotation to get it to match.
Can someone clue me in as to what is going on and which object is oriented correctly?
[Jan 9, 2022, 8:04:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: inconsistent results when rotating 2 objects
Did you draw the exported wall horizontally to ensure that once imported it's not rotated?
[Jan 10, 2022, 3:00:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
