Total posts in this thread: 43
Posts: 43   Pages: 5   [ Previous Page | 1 2 3 4 5 ]
Previous Thread This topic has been viewed 15676 times and has 42 replies Next Thread
Re: Plugins manager
The "Replace furniture" is incompatible with Java 1.8, the reason why it blocks Sweet Home 3D launch for you Keet.
I reported this issue to Olivier Martinez, and even if there's a property foreseen in plug-ins to handle incompatibilities, I made a change in Sweet Home 3D to avoid blocking the program if this property is not correctly set.
[Mar 15, 2024, 10:57:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Plugins manager
Would it be possible to display a modal dialog with an error message when a plugin fails to load (or produces an error) and after clicking an OK button continue loading Sweet Home 3D without loading the offending plugin?
This has the benefit that Sweet Home 3D continues to load and the user knows which plugin is not loaded because of an error.
[Mar 15, 2024, 12:33:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Plugins manager
I don’t think that this dialog box is such a good idea but the error will appear in the logs.
This error is due to the plug-in programmer who didn’t pay attention to Java compiler options and plug-in parameters before delivering his plug-in. There’s a warning in plug-ins developer’s guide about this and I just improved the comment in case developer’s environment doesn’t support Java 1.5 target anymore.
[Mar 15, 2024, 1:20:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
