Total posts in this thread: 5
Previous Thread This topic has been viewed 1751 times and has 4 replies Next Thread
titust11
Canada
3D View - how to adjust the color difference between N walls and S walls ?
There's a huge color difference between North and South walls, in such a way that the South walls appear very washed out, they are white if you use a pale color. In order for the walls to have a little bit of color you have to select a very dark color. Should this be configurable? The way it is right now it looks to me like a bug that can be addressed
Thanks
[Jan 26, 2022, 7:35:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D View - how to adjust the color difference between N walls and S walls ?
The 3D view is lightened by 3 fixed light sources, and there's no way to change them except if you change the program here.
[Jan 27, 2022, 8:51:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
titust11
Canada
Oui, Je comprends, mais tu ne trouve pas que les murs de couleur pale apparaissent toujours blanc?
[Jan 27, 2022, 9:02:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If walls and rooms receive all the same light, you wouldn't be able to distinguish corners anymore.
However, you can also reduce the overall lighting in the 3D View modification dialog.
[Jan 28, 2022, 11:16:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
titust11
Canada
This worked perfectly, I guess there was too much light, Thanks
[Jan 28, 2022, 9:44:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
