Previous Thread This topic has been viewed 2999 times and has 2 replies Next Thread
wofus
Problems with textures when rendering
Hello,
I added some models from 3Dwarehouse. The textures of the models are displayed correctly unless I take a 3D photo.
In quality level 1 and 2 it all displayed correctly, in quality level 3 and 4 it depends on coincidence whether the textures are displayed or not.
Photo 1 was rendered in low quality (the way it should look) - always displayed correct
Photo 2-4 was rendered in high quality - displayed textures are always random
Photo 5 was rendered with YafaRay rendering plug-in
Does somebody have the same problems?
Are the 3Dwarehouse models not compatible?
Using a Mac M1 with Rosetta.
[Mar 27, 2022, 12:07:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problems with textures when rendering
You must have imported 3D models which are double-faced with different materials (i.e. front and back surfaces are defined using a different material for each surface).
Making invisible their back face materials in the Material modification dialog box of these objects should fix your issue (generally, the material of the back faces can be quite easily guessed from their name and because selecting them in the materials list has no visual effect in the 3D preview).
[Mar 27, 2022, 4:11:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wofus
Thanks a lot for your help and also for your work on the development.
[Mar 28, 2022, 8:11:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
