kingoftailor
Re: Sweet Home 3D JS Online
What is the correct html for the new version? Later this works for me: <div id="progress"> <div id="progress-bar" style="width: 0%;"></div> </div> <div style="width:100%;height:100%;"> <div id="home-pane" style="width:100%;height:600px;position:absolute;top:75px;left:0"> <div id="home-pane-toolbar"></div> <canvas id="home-3D-view" style="display:none" tabIndex="1"></canvas> <div id="home-plan" style="background-color: #FFFFFF; color: #000000" tabIndex="2"></div> <div id="furniture-catalog"></div> </div> </div>
[Mar 28, 2022, 6:27:10 PM]
[Link]
kingoftailor
How can I set the drawing canvas to appear (full size) but not the 3d view? On earlier version this worked:#home-3D-view { display: none } #home-plan { height: 100%; width: 100%; }
The largest problem is that the buttons seems disabled: The 3. problem is that there are no right mouse context menu (sweethome online vs megveszLAK.hu test page) The test page html:<div style="width:100%;height:100%;"> <div id="home-pane" style="width:100%;height:600px;position:absolute;top:75px;left:0"> <div id="home-pane-toolbar" style="height:30px"></div> <div id="plan-3D-view-splitter" class="pane-splitter horizontal" style="display: block; width:100%"></div> <div id="catalog-furniture-pane"> <div id="furniture-catalog" style="height:100%;width:100%"> <div id="furniture-catalog-list" class="furniture-catalog-list"></div> </div> </div> <div id="furniture-plan-splitter" class="pane-splitter vertical" style="display: block; left: 330px;"></div> <div id="plan-3D-view-pane" style="position:absolute; left: 332px; width: calc(100% - 334px);height: calc(100% - 34px)"> <div id="home-plan" style="background-color: rgb(255, 255, 255); color: rgb(0, 0, 0); width:100%;height:100%" tabindex="2"> <canvas id="home-3D-view" tabIndex="1" width="1" height="1" style="width:100%;height:1px"></canvas> </div> </div> </div> </div>
The JavaScript:<script> var homeName = "emptyHome"; var urlBase = "https://alaprajz.megveszlak.hu/"; var application = new SweetHome3DJSApplication( { readHomeURL: urlBase + "homes/" + homeName + ".sh3d", furnitureCatalogURLs: [urlBase + "lib/resources/DefaultFurnitureCatalog.json"], furnitureResourcesURLBase: urlBase }); application.getUserPreferences().setNewRoomFloorColor(0xFF9999A0); application.getUserPreferences().setAerialViewCenteredOnSelectionEnabled(true); application.getHomeRecorder().readHome(homeName, { homeLoaded: function (home) { home.setName(homeName); application.addHome(home); application.getHomes()[0].setCamera(application.getHomes()[0].getTopCamera()); window.addEventListener("unload", function () { application.deleteHome(home); }); }, homeError: function (err) { }, progression: function (part, info, percentage) { } }); </script>
Thank You
[Mar 29, 2022, 10:19:08 AM]
[Link]
The CSS and HTML parts in the main page index.jsp changed a lot between versions 6.4 an 6.6, and you should probably add the changes carefully in your page.
[Mar 29, 2022, 10:57:16 AM]
[Link]
kingoftailor
Thanks, I've already done it based on index.jsp. There are two things I haven't found a solution to. I was unable to resize the drawing surface and the furniture selector jumps too wide from the initial width. How can I set the width of the furniture selector? How can I hide/remove the 3d view? How can I hide/remove the furniture view?
[Mar 29, 2022, 10:21:19 PM]
[Link]
kingoftailor
I figured it out. The furniture selector width was sette in the sh3d file (initial width). I created another emptyHome.sh3d with the windows version and the problem is resolved.
[Mar 30, 2022, 2:26:57 PM]
[Link]
Great that you could find out by yourself. Sweet Home 3D JS Online version uses CSS with well named styles for this purpose. Please share a link to the final version when it's ready.
[Mar 30, 2022, 3:35:26 PM]
[Link]
