Hi guys, thanks to this forum I was able to solve a lot of problems. Nevertheless I'm not capable to display in plan by door arc angle line. According some topic in here I tried to add to PluginFurnitureCatalog.properties the lines with doorOrWindow, but its still not working. (Door works great in 3D model, but on the 2D plan is missing the angle line. Could you please tell me, where am I doing mistake?
Re: Door - Arc Angle Line
Hi Chudst, I replaced the doorOrWindow... properties of an existing door by your properties and it worked correctly. I would suspect that you have Pokojove_dvere model in more than a SH3F file loaded by Sweet Home 3D, or maybe that you edited the properties of a SH3F file stored in private folders of Sweet Home 3D which is not a good idea. Last idea: the number of the properties ...#... in PluginFurnitureCatalog.properties file must follow each other, i.e. if it doesn't contain the name#5 the model defined by name#6 won't be taken into account.
