Total posts in this thread: 4
Previous Thread This topic has been viewed 1775 times and has 3 replies Next Thread
catalpa34
Australia
Delete background image
I've been trying to solve this for some time and I've read all the posts here I can find. Every time I create a new level, it has a background image automatically. How do I stop this behaviour?
[Apr 17, 2022, 9:29:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Delete background image
A level uses the same background image as the previous level if they are at the same elevation. If you change its order with the arrows at the right of the levels table shown in the Level modification dialog, it won't display it anymore. You could also change its elevation adding a very small value like 0.001 cm.
[Apr 17, 2022, 12:13:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
catalpa34
Australia
I'm actually thinking it's not a background image, but more like some sort of waterwark. I have two levels with a background image, which covers the watermark. I'f I hide the background image, then I can see the watermark.
[Apr 18, 2022, 8:42:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could it be shadow lines of walls on other levels you are seeing is it?
[Apr 18, 2022, 11:54:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
