Total posts in this thread: 2
Previous Thread This topic has been viewed 1664 times and has 1 reply Next Thread
Rolinger
Bosna i Hercegovina
Snap to the end of the wall
In the drawings at the junction of all the walls (according to the seismic regulations) I have to insert concrete columns. They must be shown in the draft. I want to use boxes for that. Magnetism creates a problem as it shifts the box to the front face or back face of the wall. Moving boxes manually is a painstaking task when you want to insert such, for example, 30 boxes. Is there a possibility to center the box at the end of the wall? Some kind of magnetism or “start / end point wall snap” that would center the box at the end of the wall?
Thank you very much for all possible answers.
[Jun 26, 2022, 9:59:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Snap to the end of the wall
Assuming you have to use exact dimensions and can not draw your design "freehand" using a mouse, the best way to place your boxes is using exact coordinates.
If freehand is an option, you can use the cursor keys to "slide" the boxes in place.
Alternatively, you can disable magnetism and place the boxes wherever you want.
[Jun 26, 2022, 11:54:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
