Previous Thread This topic has been viewed 5919 times and has 10 replies Next Thread
kingoftailor
Re: Sweet Home 3D JS Online
I would like to use the floor plan designer in such a way that it can be used on desktop, tablet and mobile.
For example, the user goes to an apartment and draws the floor plan on a mobile phone, then completes it on the desktop computer and prints it out.
I found several problems. The biggest problem is that the canvas on the mobile version and the desktop version have different sizes, so they are not compatible with each other.
The second problem, which is also present in the desktop version, is that the parts of the floor plan that are too large, protruding from the visible surface, are not placed on the saved image (the floor plan view must be reduced so that the entire floor plan is visible, i.e. the entire canvas is not placed on it to jpg, only the visible part of the canvas).
[Aug 11, 2022, 10:41:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As screens don't have the same size on various devices, the displayed elements may not have the same sizes from a device to the other one.
The Online version is able to print what the browser accepts to print.
I just added a @media print CSS query to print only the plan and the 3D view, but only Safari seems to generate a correct page, other browsers giving more or less nice results.
If you want to print at a given scale with a more predictable result, you should print with installer version.
[Aug 12, 2022, 11:36:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kingoftailor
The problem is not with printing, but with saving as an image:
function DownloadAsImage() {
let downloadLink = document.createElement('a');
downloadLink.setAttribute('download', 'plan.jpg');
let canvas = document.getElementById('home-plan.canvas');
var planView = application.homeControllers[0].planController.planView;
var oldGridColor = planView.gridColor;
planView.gridColor = "white";
planView.repaint();
setTimeout(function () {
let dataURL = canvas.toDataURL('image/jpg');
let url = dataURL.replace(/^data:image\/jpg/, 'data:application/octet-stream');
downloadLink.setAttribute('href', url);
downloadLink.click();
planView.gridColor = oldGridColor;
planView.repaint();
}, 100);
[Aug 12, 2022, 1:47:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
But... this is not a function provided with Sweet Home 3D JS Online!
You should probably create a different plan view at the dimensions you prefer, but I don't know if it will work if that view is not displayed.
[Aug 12, 2022, 2:06:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kingoftailor
That's right, but you also posted in the blog that this is how you can save it as an image.
No idea why it doesn't save the whole canvas?
It looks like this:
[Aug 12, 2022, 2:56:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I never posted the code you cited in your message, but maybe the following JavaScript code that I tried in the console to save current plan view in an image will be helpful:
plan = application.getHomeController(application.getHomes()[0]).getPlanController().getView();
canvas = document.createElement('canvas');
canvas.width = plan.getPreferredSize().width * 2;
canvas.height = plan.getPreferredSize().height * 2;
plan.paintComponent(new Graphics2D(canvas));
link = document.createElement("a");
link.setAttribute("href", canvas.toDataURL());
link.download = "test.png";
link.click();
PS: please create different threads for this kind of support requests. This thread is for general information about Sweet Home 3D JS Online.
[Aug 12, 2022, 4:11:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kingoftailor
It's almost good. There is only a problem with the background color. It should be all white. (The invisible part is not white)
function AlaprajzMentes() {
downloadLink.setAttribute('download', 'alaprajz.jpg');
var planView = application.getHomeController(application.getHomes()[0]).getPlanController().getView();
planView.repaint();
var canvas = document.createElement('canvas');
canvas.width = planView.getPreferredSize().width * 2;
canvas.height = planView.getPreferredSize().height * 2;
planView.paintComponent(new Graphics2D(canvas));
planView.repaint();
}, 100);
[Aug 12, 2022, 7:25:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe fill the canvas with white color.
[Aug 12, 2022, 7:41:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kingoftailor
The problem was that a new canvas was created. This is how it works:
planView.repaint();
window.location.reload();
}, 100);
[Aug 13, 2022, 11:49:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great you found out, but your solution modifies some attributes of the existing canvas and planView without resetting their values once done. This may have some visible effects on screen…
[Aug 13, 2022, 12:19:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
