Previous Thread This topic has been viewed 11436 times and has 2 replies Next Thread
voldan
A couple of questions
I just started using Sweet Home 3D and first let me say thanks, I love this program.
I did ran into a couple of problems for which I hope someone has some ideas how to solve...
  • I have an opening in a wall which is from the floor but not all the way to the ceiling. Is there a way to model openings in the wall or do I have to simply not put a wall there and then create some furniture which starts at an elevation?
  • Is it possible to group objects and save them as a group (as opposed to multiple select?) I saw that grouping is something which was added in version 2 but I am not sure if it is limited to multiple select.
  • while on the subject of group, is there a way to rotate and scale a group (either in selection or as a saved group if available)?
  • Somehow I managed to create copies of an entire area. Could someone point me as to what are the keys for that (so I'll be more careful) and if there is a way to find out where it happened (other than start moving walls and see if another is beneath them)?
  • I need to make a round wall. I saw in the FAQ that currently it is only possible as a large number of small walls. I was wondering what effect if any would be to simply create a furniture instead of the wall and if there is such a furniture ready where I can download and use it or do I have to create one myself (and if so any suggestion on how to do it without having to learn too much...)
  • Is there a way to set the default texture of walls and furniture (instead of white) or do I have to add them each time?
  • I have many walls in an angle. I saw that it is possible to see and change the angle when creating the wall, is there a way to do it when the wall is already created (other than calculating the angle manually and then setting the position accordingly)?
  • Also with walls in an angle, sometimes windows and doors do not snap to a wall in an angle (even when the magnetism is enabled). Is there a way to manually do it?
  • When I do measurements in my house I measure the inside of the walls but when I create a wall in sweet home I enter the full length (which is from the middle of the adjacent walls). Now if I am on the grid it is easy to calculate, is there an easy way to do it for angled walls also?
  • Is there a way to manually connect/disconnect walls? Currently I can only connect walls when I initially create them and I don't know how to disconnect them later if I need to.
  • Does someone know if there is a model of a sliding door somewhere?
Sorry for the long post, I hope someone knows some answers/tips for me.
Thanks.
[Dec 2, 2009, 8:54:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A couple of questions
Use the models named Door frame or Service hatch in the Doors and Windows category with an elevation equal to zero.
If the top of the opening is round, use a Service hatch and an elevated arch as suggested in this example.
Grouping will be added in the coming versions. At this time, the only way to group objects is to copy/paste them in a new empty home, export that home to OBJ format with 3D view > Export to OBJ format... menu item, and import the exported file in the first place with Furniture > Import Furniture... menu item.
Same answer and same tip...
You can duplicate any object by keeping the Ctrl key pressed during a drag and drop operation (or Cmd key under Mac OS X).
You idea about a 3D model looking like a round wall part is probably the best idea, and I should have thought about this workaround a long time ago. wink
I just added a new model in 3D models import page, and will update the FAQ accordingly.
No, but you may select all the items your want to modify in plan, and choose Furniture > Modify..., Plan > Modify walls... or Plan > Modify rooms... out of the menu to modify all the selected pieces, walls or rooms.
No. It's not that it's too complicated to program, but I feel it wouldn't be that useful.
I guess you tried to change the location of the end points of a wall, and then the windows or doors placed on this wall looked incorrect, am I right?
If this a case, you'll have to move again each window or door on the wall so they are correctly placed into the wall.
If I didn't understand you, please give more details.
First note that the easiest way to enter the exact length of a wall at creation time is to press Enter key, and then enter values with the keyboard. If you want to draw a room with a special shape but can't import its plan as a background image, I would create it with the Create rooms tool, enter its measurements with the keyboard, select the Create walls tool then double click in the room to create walls around it.
To disconnect a wall use Cut / Paste. There's no way to connect an existing wall at this time.
Read also this thread.
See in Bedroom category. These sliding doors are not among Doors and windows category because they don't create holes in walls.
[Dec 2, 2009, 4:53:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
voldan
Thanks for the prompt reply.
I tried to use the round wall model, however it shows me a big square when in the 2D window (I am using the top view option for furniture in the plan). How do I correct that?
As for placing doors and windows on walls in an angle, what happened was that I changed the end point of the wall and then wanted to move the window to the correct place, problem was it wouldn't snap in, what I had to do was rotate it manually and position it manually without snapping. It is not always like this, most of the time it snaps correctly but sometimes (especially when the change in the wall is small and the door/window is near the edge) it just won't snap. So I thought maybe there is a way to manually snap it...
Thanks again.
[Dec 2, 2009, 7:21:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
