AU
Constant Fatal Freeze Now. Will Not Open Previous Files.
i am not sure that it is anything to do with new Plugins i just installed, but my SH3D suddenly -
- will not open previous files (and earlier would not do 3D in separate window) - will not close app - will create NEW test plan, and it will do 3D, but will not save or close - i have uninstalled some but not all Plug-ins, and actually all Plugins are working (incl Plugin Manager which is very nice)
it seems to me to be related to new Plugins, otherwise that would be a big co-incidence
Re: Constant Fatal Freeze Now. Will Not Open Previous Files.
If you think one or more plug-ins might cause these issues, you should remove all of them (see Plug-ins page for information about uninstalling plug-ins) and test them individually. I hope it's not a combination of plug-ins because it might be more difficult to test.
AU
hmm. i suppose that would be better than simply re-installing because i would have to reinstall PI anyway.
AU
update. odd. i reinstalled- from the site, and SH3D user interface quite different, in particular and most obvious, the top menu bar is much more enhanced with icons for all the plugins
everything working, incl 3D, and all the plugins that were previously installed are still there (and apparently working)
makes me wonder if previously i had an old version installed unknowingly. i tried to check in Recycle to see if i could see previous exe file, but can't see anything.
so have to explore what i have now; and also try to make sense of object and texture library downloads
