Total posts in this thread: 9
Previous Thread This topic has been viewed 2311 times and has 8 replies Next Thread
hobbyrv
system stops
Sometimes the program stops working, I close via task manager, then usually it works again. But now not anymore, objects only partially load and I can't click on anything. What to do and how?
[Sep 17, 2022, 11:23:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Re: system stops
See screenshot, in addition: http://icecream.me/578878ccd058aaac42c3a7108e36c228
[Sep 17, 2022, 12:46:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: system stops
Check in About dialog box if you installed the 32 bit version. If it’s the case, run the installer again and choose 64 bit architecture in the screen which lets you choose the installation folder.
[Sep 17, 2022, 3:50:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Re: system stops
Perhaps a stupid question, but what dialog box do you mean?
[Sep 18, 2022, 9:55:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Re: system stops
I found it, but it's 64 bit already, zothat isn't the cause.
[Sep 18, 2022, 2:27:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: system stops
If you share your file, I can see if I get the same problem.
[Sep 18, 2022, 4:16:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Re: system stops
Heb je private message ontvangen? Ik zie het niet terug namelijk in het overzicht. Vraag is o.a.hoe ik de file kan toevoegen, ik zie geen optie voor bijlagen.
[Sep 20, 2022, 7:16:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Re: system stops
Ik heb nog even verder gekeken en zie dan dat mijn pc wel 64 bits is, maar Java 32. Kan het daar mee te maken hebben? Kan ik dan zonder problemen Java 64 downloaden?
[Sep 20, 2022, 2:01:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: system stops
Dat zijn dingen waar ik weinig verstand van heb, maar het lijkt me logisch dat je op een 64-bits syteem 64-bits software gebrukt...
[Sep 20, 2022, 2:21:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
