Total posts in this thread: 5
Previous Thread This topic has been viewed 2373 times and has 4 replies Next Thread
rblaust
Update 7.0.2 Not Working on Windows 11
I've been using Sweet Home 3D on Windows 11 for over a year with no issues. Then I installed the 7.0.2 update version and now when I try to launch the application I get the "could not create the java virtual machine..." message. I have tried uninstalling and re-installing JAVA, rebooted (multiple times), made sure Windows was up to date, increase the RAM for JAVA and nothing has helped. Please help. As of now the application is dead.
[Oct 21, 2022, 3:03:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Update 7.0.2 Not Working on Windows 11
Sweet Home 3D installer comes with its own copy of Java, and you shouldn't have to install it on your side unless you need it for other purposes. But this shouldn't cause problems too.
Did you install the 32 bit or 64 bit version (see Architecture option in installer)?
[Oct 21, 2022, 10:09:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rblaust
I installed the 64 bit version
[Oct 21, 2022, 11:45:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could you try to install the 32 bit version?
[Oct 22, 2022, 4:59:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rblaust
The 32 bit version worked! Thanks for your help.
[Oct 23, 2022, 1:03:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
