Previous Thread This topic has been viewed 2131 times and has 2 replies Next Thread
Smitty789
United States
Import From RoomScanLiDAR Levels Not Aligned
Hello,
I've used RoomScanLiDAR on my iPhone to create a floor plan of my house. I've exported the file to a Sweet Home 3D Plan. I'm running into an issue where the Entrance Floor and the 2nd floor do not align.
I tried the rotate plug in but then realized that this rotates the entire plan and not each level individually.
Can anyone help me align my first and second floor properly?
I apologize if this issue has already been addressed. I've searched around and can't find anything to help me.
Thank you!
[Nov 5, 2022, 2:25:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Import From RoomScanLiDAR Levels Not Aligned
If I understand you correctly you have a level that is rotated according to one or more other levels.
If that is the case you can select everything (ctrl-A) on a level and use the rotate funtion that comes with the AdvancedEditing plugin. You can rotate with any arbritary angle and of course repeat it with all levels that need rotating. You might have to move everything too to get a correct line-up but that function is also available from the same plugin (main-menu icons are added after install of the plugin).
Mind you, the rotate function rotates everything selected: furniture, walls, rooms, polylines, dimension lines, etc. Exactly what you need.
[Nov 5, 2022, 4:12:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Smitty789
United States
That worked perfectly. Thank you very much!
[Nov 5, 2022, 6:40:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
