love struck How do I close my walls?
This topic has been viewed 3699 times and has 3 replies
Thread status: Active
Post Reply New Topic
function10
Post by function10 »
When I draw 4 walls, how can I get the ending of wall 4 to neatly fit with the starting point of wall 1?
Looking at the image below, my problem is the left hand corner. The right hand corner is not boxy. The right hand side corner is an automatic join when I click several times to place multiple walls.
User avatar
Country: Paris, France
Contact:
Re: How do I close my walls?
Post by Puybaret »
Double click on the start point (the starting wall will be colored when you approach it), or afterwards, use the Plan > Join walls menu item (see this article).
User avatar
Moderator
Country: Netherlands
Post by Keet »
Select the two walls you want to connect, right click, and choose 'Join walls' from the context menu.
function10
Thank you Puybaret & Keet.
I did not see that info here: https://sweethome3d.com/userGuide.jsp#drawingWalls
