Total posts in this thread: 8
Previous Thread This topic has been viewed 3758 times and has 7 replies Next Thread
KitchM
What Is Magnetism
Is magnetism the same as snap-to? It sure looks that way from the video tutorial.
[Dec 6, 2022, 9:06:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: What Is Magnetism
Magnetism doesn't snap to the grid. Otherwise, please search for magnetism in the help, it's cited in many pages!
[Dec 6, 2022, 9:17:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
Yes, you are correct that the word shows up multiple times. However, it is not defined in its function nor in relationship to snapping to a grid; which is a reasonable expectation. The novel way it is used in the program dictates a need for a definition.
[Dec 7, 2022, 5:01:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Magnetism is between objects. Snap-to-grid is not magnetism, but as you stated yourself, snapping to the grid smile
I'm not aware of any program where snap-to-grid is called magnetism.
[Dec 7, 2022, 5:53:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
So the use of "magnetism" in this program is where one object is attracted to another.
Can you explain the use of such a feature? Is it like a chair to a table, or is it like the end of one line to the end of another?
[Dec 7, 2022, 6:58:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The most common occurance is where doors and windows slip into a wall and adjust themselves to the wall thickness.
If you drag furniture against a wall it sticks and orientates against the wall so you don't have to manually fit it against the wall.
Objects can also be dragged against each other and have a magnetism point where they 'stick' together, also for easy placement.
Magnetism also causes furniture rotation and wall angles to occur in steps of 15°.
If you switch magnetism off you can set any angle, place doors and windows without deforming into a wall, and move objects over each other without sticking against each other. This is all with mouse movement. When using the arrow keys magnetism is ignored.
[Dec 7, 2022, 9:33:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
Thank you for the good info and explanation. This makes it easier for all.
[Dec 7, 2022, 10:24:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JessieJim
Yes thanks for explanation!
[Dec 14, 2022, 4:31:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
