Previous Thread This topic has been viewed 4588 times and has 2 replies Next Thread
Jeypee
Germany
confused Silent Installation with 64bit dont work
Hello,
today i tried to install the newest Version 7.0.2 over command line in 64 bit.
All Parameters are visible with "SweetHome3d-7.0.2.exe" /?
First i started with the parameter "/SAVEINF="SweetHome3D.inf"
Installed in "64-bit" - all ok. After that i uninstalled it.
Next i tried with "/loadinf="SweetHome3D.inf" but it installed in "C:\ProgramFiles (x86)" < 32 bit.
In the Inf File is an Parameter: Dir="C:\Program Files\Sweet Home 3D"
I also tried with "/DIR="C:\Program Files\Sweet Home 3D" but it installed also in the 32-bit Directory ?!
My Problem is that no silent installation works. Here my parameter:
SweetHome3d-7.0.2.exe /SILENT /NORESTART /NOCANCEL /DIR="C:\Program Files\Sweet Home 3d" /LOG="SweetHome3d.log"
Dont work - just 32-bit. Only manuel 64-bit works :-(
Please help
[Jan 30, 2023, 1:48:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Silent Installation with 64bit dont work
Adding /os.arch=x64 parameter should do the trick. See also installer parameters described at the end of this article.
[Jan 31, 2023, 7:09:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jeypee
Germany
smile Re: Silent Installation with 64bit dont work
Thank you very much. That works.
Should be stay here:
http://www.sweethome3d.com/faq.jsp#installation
[Jan 31, 2023, 8:52:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
