Is it possible to set dimensions to automatically adjust if wall length is modified ?
Hi.
I am new to Sweet Home and I have a lot to learn. One thing I could not find the answer to, is if there is a feature that can make dimensions I set (in 2D) to wall lengths can be locked to the start and end of the wall so that it is automatically updated if I should modify the length of the wall ?
The way it works for me now is that if I attach a dimension to a wall, and then change the wall length to be longer or shorter, the dimensions is not changed accordingly, the start and end points are in the same place and the value is still showing the value that was valid before the change.
Re: Is it possible to set dimensions to automatically adjust if wall length is modified ?
Dimensions are not bound to the object they measure, and you should adjust them or delete / create them again if needed.
