How to create your own texture libraries?
Hello to all, For the furniture I create, I use the ExportToSh3f plugin then the FurnitureLibraryEditor to create my own .SH3F libraries On the other hand, when I import my own textures in Sweet Home 3D, I don't know if there's a plugin allowing to export them in SH3T before their eventual integration, in my own .SH3T libraries, via TexturesLibraryEditor. If someone has an answer or a solution to integrate my creations in a personal library, I'm interested. Thanks for your help.
Re: How to create your own texture libraries?
Hello Vinci68, As you noticed, there was no plug-in to export textures imported by a user to a SH3T. Actually, I don't think anybody requested such a feature even if it could be useful at least for backups (but there are other ways to backup preferences and imported stuff). As it's quite close to ExportToSH3F plugin, I just programmed the ExportToSH3T plug-in available here (it requires a Sweet Home 3D version >= 2.3). Similarly to ExportToSH3F plugin, this plug-in adds Furniture > Export imported textures to SH3T menu item to Sweet Home 3D to create a SH3T file which will contain all the textures individually imported by the user. If needed, this SH3T file can be edited with the Texture Library Editor.
[Note: plug-in was updated on 03/04/2024 to fix Italian localization]
[Edit 1 times,
last edit by Puybaret at Mar 4, 2024, 2:21:57 PM]
Hello Emmanuel No sooner said than done... If there was a Palme d'Or for this type of exercise, I think you could be decorated in public. In any case, thank you for this effort, and this tool which will be very useful. Have a good weekend
