Total posts in this thread: 5
Previous Thread This topic has been viewed 10969 times and has 4 replies Next Thread
vil_br
Brasil
Suggestion - 3d Extrude tool
I would like to suggest a 2d to 3d extrusion tool, which is based on simple vector files such as svg, I believe it would be very useful for both decorating items and also creating commercial facades among other applications, thank you.
example
[Apr 25, 2023, 2:44:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
Re: Suggestion - 3d Extrude tool
You can make 10 as floor thikness, draw room as a vector, and save the room as a furniture
[Apr 26, 2023, 10:35:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
this way you only get 1 available material to modify .. it woul dbe nice if we could modify every faces .. RoofPlugin does it .. why not thecopyasnewfurniture?
[Jun 5, 2023, 10:12:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can "fix" that but you will have to edit the obj and mtl files.
In the obj file give every g group a unique "usemtl <name>" line. In the mtl file create a block for every one of those names. The exact color is not important yet.
Import the obj file and now you can change every part of the object.
You can see what material name is for each part of the object so you can edit the obj/mtl files again if you want to give them meaningful names. You might not have every single face but more than when you started. Thats how far you can go with Sweethome3D.
If you are familiar with Blender you can use a different method: import the obj file in Blender. You can see each group in the list and assign a different material to each group. You could even assign different materials to every face. Export the object and import in Sweethome3D.
[Jun 5, 2023, 10:45:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
it's a long way since you only COPY as a new furniture and PASTE with the plugin.
i suppose it's not a big fix for the developpers to be able to get all the faces at the pasting
[Jun 5, 2023, 11:38:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
