Previous Thread This topic has been viewed 2768 times and has 2 replies Next Thread
Soulis
United States
confused Installing 3d content
How do I install the 3d object files into sh3d?
Do villains see themselves as saviors, as would a hero? Based on the fact that most comic book villains (e.g: Marvel/DC) their motives are that they are trying to save or right some wrong. So are they really villains, anti-heroes or Anti-Villains?
[May 24, 2023, 4:34:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Installing 3d content
Follow the guide!
This video may help you too.
[May 24, 2023, 5:13:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
One feature not mentioned in the guide is that you can drag-and-drop an object file from a file browser into the Sweethome3D 2D window to import it. This is the method I always use instead of the import through the menu because it's easier and faster and most important: you can drop at the position you want and avoid the default 0,0 position.
Another advantage is that you can select multiple object files and drag them all at once into the 2D window. For each file you get the import wizard and all at the position where you drop them. Works perfectly!
Unfortunately this method doesn't work with furniture libraries (.sh3f files) but maybe that will be fixed in a future version.
950+ 3D models, manuals, and projects
[May 25, 2023, 7:37:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
