Re: Object priority when stacking
Like Hans said Sweethome3D can't do this but with a little creative manipulation it can be done. How easy it is depends on how detailed the cabinet object is constructed. In this case: more detail makes it easier.
-1- You are really lucky if the top has it's own texture property when you modify the cabinet. You will not need Blender! Make the top invisible and export the cabinet. After import you have your cabinet but without the top. Go to -3-.
-2- If you are not that lucky you will have to open the cabinet in Blender. If you are lucky the top of the cabinet is a separate group. Select that and delete it. If the top is not a separate object you will have to manually delete all vectors for the top. Export as obj. Import this in Sweethome3D you have the same cabinet but without the top.
-3- Place the sink where you want it in the cabinet.
-4- Now add resized boxes to fill in a new top around the sink. Make sure you keep the same direction for the boxes (i.e. all front faces point in the same direction). This is so that a new added texture to the boxes follow the same direction. You will probably need 4 boxes: left and right of the sink and front and top of the sink. Select the cabinet, boxes, and sink and export this to your new cabinet with sink.
-5- After import your cabinet will have the same texture options as before. The new cabinet top has the original box properties bottom, top, left, right, front, and back. By setting these properties you set the cabinet top. The sink has the same texture property as before.
You can change the properties for the top if you want. I'll explain that if you decide to try it the way I described. It requires manual editing of the obj and mtl files.
There are other ways, for example creating a new top by using a room and importing the sink as a staircase to create the hole for it. Or you can manually draw a room as a new top. Like I said: creative manipulation
Dodecagon.nl 1300+ 3D models, manuals, and projects
[Jun 22, 2023, 2:15:29 PM]
[Link]
