Total posts in this thread: 12
Previous Thread This topic has been viewed 10119 times and has 11 replies Next Thread
411621
3D rendering using GPU cores
What would be a wonderful solution for the rather extreme slow rendering of 3D images. Especially the very long rendering time when images are needed in higher resolutions i.e. 4000 pixel.
A 3D rendering engine that uses all the GPU cores of a modern video card i.e. Nvidia.
That would be awesome!
[Aug 22, 2023, 6:50:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D rendering using GPU cores
Something like the Cycles renderer as used by Blender, Poser, Rhino. Open Source so well suited for Sweet Home 3D.
I have a brand new RTX4070 waiting in the box for my new machine to get back from repairs. That would make it fly smile
[Aug 22, 2023, 7:22:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enigmaxg2
El Salvador
This has just released, I think it could be of help since makes Java apps to run on GPUs, FPGAs and more.
https://github.com/beehive-lab/TornadoVM
[Dec 6, 2023, 2:12:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
The render engines used in SH3D aren't written in java, they are external native code called using JNI.
By the way I'm working on a solution to unload our CPUs while rendering, I will provide more details in the next weeks. Stay tuned!
[Dec 6, 2023, 8:30:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry, but SunFlow is written in Java.
[Dec 6, 2023, 9:13:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
@Puybaret
Thanks for having pointed it out, I wrongly assumed that it uses a DLL like Yafaray does.
About porting java code under TornadoVM, I ask myself how much easy could it be. From a first look it seems that it's easy to port pieces of code that already looks like code that should run on a GPU (such as kernel operations), so I wonder how much of SunFlow is affine to this porting, considering that it has been designed to run on a CPU and may have just few routines that match the requirement.
A relatively easy improvement could be to not change SunFlow at all, but to implement an additional denoising step that would allow to have smooth images without having to render at larger resolution than required just to shrink them back to destroy the scratches. This could be applied after the rendering made with any engine, so the denoising code can be shared for both SunFlow and YafaRay. However, to reach the state of art in denoising algorithms, the render engine should be modified to output not just the pixel colors, but also the normal vectors of the rendered surfaces.
By the way I also wonder if anyone is going to try this integration.
[Dec 7, 2023, 10:23:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GaudiGalopin3324
Russia
applause Re: 3D rendering using GPU cores
I'm reading with bated breath. Dear gurus. Please do something else for all of us. I will make a wish for the New Year so that the rendering will be faster). And we really need a fast YafaRay.
[Dec 7, 2023, 7:29:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Loule
FR
Hi, any news about that? :)
[Dec 21, 2023, 9:40:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Don't believe too much in Santa Claus.
If it was simple, it would have been avalaible for a long time.
[Dec 22, 2023, 1:37:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
I can give a little anticipation: the solution I'm working on will be cloud based, that means that you won't need to buy costly hardware to speed up your renderings. But, even more worthly, you can continue working on your home, or just power off your PC while the rendering is executed in the cloud. And, moreover, you will be able to render files made with SweetHome 3D Online, without the need to install the program on your PC.
[Dec 22, 2023, 2:53:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
