Total posts in this thread: 2
Previous Thread This topic has been viewed 1697 times and has 1 reply Next Thread
411621
How to do sloped floors, ramps & ceilings?
I need to draw on occasions slope floors, ramps and sloped interior ceilings.
How can I do that In a simple way? I was looking i.e. for the floor function to have a sizable thickness function.
For example a function were I have a rectangular floor and I can enter that on point A is 0, point B also 0 but on point C and D is 4 inches higher. Thus depending on the length between A to C and B to D accordingly the slope is.
This would be typical for a garage floor which slopes down towards the garage door.
Ceilings are a similar situation. Let's say a ceiling across the room inclines from the standard room height by the window towards the other side by 1 m or feet whatever you're measure in.
[Sep 24, 2023, 8:46:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to do sloped floors, ramps & ceilings?
You can't slope a room (floor) but you can use a triangle for a sloping garage floor or a ramp. Alternatively you can use a very wide and low wall, from 0.1 to 4 inches on the other end.
A sloping ceiling depends on what king of ceiling you want. The most common way is to use a box that you tilt. If you need a hole in the ceiling: first create a wall the size of the ceiling and insert a service hatch where the hole must be. Export wall and hatch, import and tilt.
[Sep 24, 2023, 9:13:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
