Total posts in this thread: 4
Previous Thread This topic has been viewed 1161 times and has 3 replies Next Thread
libertyline
United States
smile How to create radius measurements?
Hey everyone!
New user here. I am a general contractor building homes for disabled veterans.
One of the requirements to be shown in floor plans is the turn radius minimum requirements for a wheelchair (generally 3'-4').
They want this to be shown as a circular radius measurement, not simply a linear measurement between obstacles.
I will attach an image link as an example.
Is this feature available on Sweet Home 3D?
https://drive.google.com/file/d/1Lbq_CwWqxAbR...fFUYG/view?usp=drive_link
[Nov 1, 2023, 12:15:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to create radius measurements?
If >I< had to do this, I would use walls...
1 - draw a wall from A to B, than back to A
2 - Use Modify Walls - change Height and Thickness to 1 or 0.1, and Arc Extent to 180 - this gives a perfect circle that looks like a line
3 - Add Dimensions manually, or use Autodimensiong plugin (link).
[Nov 1, 2023, 9:16:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You could also use this PWD symbol model designed for this purpose. It just different materials in case you want to show only the wheelchair symbol or the circle.
[Nov 1, 2023, 9:24:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
libertyline
United States
perfect, THANK YOU!
Great community here, I appreciate the quick reply!
[Nov 1, 2023, 5:50:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
