Search furniture for "Keywords"
Using SH3D 7.2. Question: how can I search the furniture by Keyword? I know them from the furniture editor, but in the main program keywords are not displayed.
Re: Search furniture for "Keywords"
Bonjour.
Cliquez sur l'icône "Editer les préférences". Celui ci une fois ouvert, à la ligne "Catalogue des meubles", choisissez "Liste avec recherche" et faites "OK". Ne vous reste plus qu'à entrer le nom du meuble dans la case "Recherche".
En espérant avoir répondu correctement à votre question.
Quickly said in English: select Searchable list option in preferences panel, then use the search text field above the catalog.
The searchable list should be the default. It's filter function is very powerful: you can enter multiple, even partial, keywords and it will filter accordingly. For example "kitch spoo" will find all spoon models, probably even if only "spoo" is used. And that is not only on the visible category and model names but also the keywords that are added to the model in the furniture libraries which you don't see. Works very fast too.
Thanks for the easy solution. Sounds more useful then the category list. I can never decide to put the sink into bathroom, kitchen or workshop category. Keyword "sink" and all the sinks are listed. I will try!
