Romania
Regular room plugin
Regular room version 1.0 In the series of YAUP another useless plugin under a motto: "Sometimes even simple things are hard to do." With a little CAD could be more easy. It could be found under Tools and on tool bar as a pentagon icon. This plugin generate a regular room between 3 to 30 sides. You have to input the sides number, the length of the side and the room center position. It look like this:
Also on Source Forge.
Re: Regular room plugin
This will make creating my dodecagon shapes a lot easier. Until now I used dodecagon shapes created in Blender as parts for furniture or buildings. In Blender you can set the number of sides for a cylinder similar to your room plugin. This especially makes it easier for me when I need walls/rooms with a specific lenght. YAUsefulP. Thank you Dorin.
Thanks a lot Dorin, one more step to the realization of furniture and objects with SH3D... I'm using Sketchup less and less and I'm now making a lot of things directly in SH3D!
Romania
News in version 1.1 -add Chinese translation thanks to YGYL -increase sides max number to 300 (hope it is enough even for Keet ).
Also on Source Forge .
Thank you, I think that is enough With 300 sides it might even be smoother than a cylinder.
(The plugin manager seems to have a little bug regression: the "Plugin installed ...Ok" close window hides behind the main window again.)
