Previous Thread This topic has been viewed 4037 times and has 9 replies Next Thread
ArvinJo8
Mauritius
Taking too much time to render. Can someone help please?
PC Specs
Window 11 Pro
Graphic Geforce RTX Nvidia 3080
i7 12300
32gb ram
1tb ssd
1tb hdr
Only 4% of GPU is in use and 25% of CPU (how to increase it consumption so as to make the rendering much faster?)
Paid version of Sweet Home 3d from Microsoft Store
All plugin install
[Apr 14, 2024, 6:12:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Taking too much time to render. Can someone help please?
The current renderers (SunFlow & YafaRay) use the CPU for rendering, not the GPU so it's no surpise that the GPU load is low.
What you can try is to increase the amount of memory Sweet Home 3D is allowed to use. This might avoid some swapping and should increase the overall speed.
How-to is described here: http://www.sweethome3d.com/faq.jsp#increaseMaxMemory
The time needed to render mainly depends on the complexity of what you render. A tree takes a lot longer than a simple box. Textures take more time than colors. If you can simplify the scene you want to render this should help more than anything else you can do.
[Apr 14, 2024, 8:26:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
General tips to reduce render times:
- use small models (in Kb) with low poly count (e.g. avoid trees/plants)
- use few light sources
- avoid mirrored and/or transparent surfaces/objects
- make invisible what is not in the image (models/levels)
- use no or small textures (512x512 pixels is generally enough)
[Apr 14, 2024, 12:00:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
subia75
Italia
Hi, I'm connecting to this post,
I took back my file of my house with garden after 2 years because I made some changes.
It's a 200mb file but,
I remember that it took me 15/20 minutes to render
Now for the same file it takes more than 1 hour.
I don't understand why.
I always use the same PC, so could it be that there is some difference in the program after 2 years of updates?
I'm thinking of trying an old release to see if it was lighter.
[Aug 7, 2024, 3:38:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Run again the installation program and select the 64 bit architecture when prompted.
[Aug 7, 2024, 9:57:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
subia75
Italia
if the answer was for me, the installation is already 64bit
[Aug 8, 2024, 9:36:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you select YafaRay rendering engine?
[Aug 8, 2024, 10:42:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
subia75
Italia
I use Sunflow, I'll try to do some tests with YafaRay.
Then I'll let you know how they went.
thanks
[Aug 8, 2024, 12:35:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try to render at the same resolution as before? A higher resolution takes longer to render. Unless you know what resolution you used for the old rendering it's easy to make the 'mistake' of trying to render with a higher resolution.
[Aug 10, 2024, 12:52:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
subia75
Italia
Yes, I'm sure of the same resolutions because I save a scrren of the settings I use.
I also tried with YafaRay engine but it takes longer.
As soon as I can I try to load an older release just to do a further test.
[Aug 12, 2024, 12:54:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
