Total posts in this thread: 4
Previous Thread This topic has been viewed 5925 times and has 3 replies Next Thread
How to make transparent textures
Hello all :-)
Does anyone have a suggestion how you can make semi-transparent textures?
I can think of several scenarios:
- Partially transparent walls: here I want to apply a texture to a wall. Where the GIF or PNG image is transparent, the wall should be transparent as well.
- Partially transparent objects: let's say I create a cube with a texture applied to one face. Where the image is transparent the cube should be transparent as well.
These images help explain what I want to achieve.
I tried some variations, but sofar without success.
Hopefully someone has good suggestions.
[Edit 1 times, last edit by hansmex at Feb 2, 2010, 1:22:21 PM]
[Feb 2, 2010, 1:20:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
peefy
Re: How to make transparent textures
I am interested in how to do this as well.
Anybody any suggestions?
Thanks!
[Sep 11, 2024, 4:50:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A basic search would give you many answers to accomplish this.
Depending on your system you can use one of the suggested solutions here: https://www.makeuseof.com/how-to-make-background-transparent/
If you only have a single image you want to convert there are many online sites where you can do easily this for free.
I always use GIMP. Basicly you add and aphachannel to the image and set the transparency to a selected color. The link I gave also explains how to remove a background for an image using different graphics programs.
Remember to save in a format that supports transparency, for example PNG. (JPG doesn't support transparency.)
[Sep 11, 2024, 7:15:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captaincook
Bonjour.
J'ai aussi découvert par hasard une possibilité de Power Point (pour ceux qui l'utilisent) et c'est très pratique.
Regardez la vidéo suivante.
https://youtu.be/zvEbOjns9Tc
J'ai testé et ça marche très bien.
Adobe Express, une application en ligne gratuite, est aussi très intéressante et très simple à utiliser.
Image initiale :
Image produite par Adobe Express :
L'arrière plan, qui apparait en blanc sur l'image, est en fait transparent.
Texture obtenue et appliquée sur la face avant d'un cube de 100*100*1 dans SWH:
Image finale en 3D dans SWH:
[Edit 1 times, last edit by captaincook at Sep 12, 2024, 12:02:15 PM]
[Sep 11, 2024, 12:29:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
