Re: How do I get rid of Sweet Home 3D graphic on my desktop?
Could you explain what you mean by a "large graphic overtop"? Maybe with an image showing the problem.
Do you mean the SweetHome3D splash screen? Is it possible that the installer tries to start the application, and for some reason the process has hung with the splash screen still displayed?
If so, you will need to hunt down the associated java process in your system monitor (depends on your OS type) and kill that process.
No need to bother how to paste the splash screen here. It won’t give any additional information. Do you use the latest version of Sweet Home 3D? Did you install some plug-ins?
You can reinstall the program if you want. If it still fails, please report program logs following these instructions.
