Previous Thread This topic has been viewed 1525 times and has 13 replies Next Thread
A.D.STUDIO
Australia
3D View "Display In Separate Window" Causes Hangs
Thanks for the 7.4 update. There's a note about separating the 3D view on a separate monitor would cause freezes but now fixed. However, I separate this window on a single monitor and I can guarantee a hang after toggling around six times. This is with ONE model in the plan.
[Jun 4, 2024, 9:45:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.D.STUDIO
Australia
Re: 3D View "Display In Separate Window" Causes Hangs
I think there's a severe memory leak going on, my RAM is maxed out after doing this...
[Jun 4, 2024, 9:56:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Thanks A.D.STUDIO!
I've encountered the same problem even I'm under linux (debian) on both computers (at work and at home).
Symptoms: SH3D don't start even with an empty file.
Result in konsole:
library initialization failed - unable to allocate file descriptor table - out of memory
Solution for linux users found on the net:
What fixed it was this command as root (su -) (sudo didn't do it):
echo >/etc/security/limits.d/systemd.conf "* hard nofile 1048576"
Then reboot.
Solutions found here and here .
I hope it will help someone.
[Edit 1 times, last edit by dorin at Jun 4, 2024, 4:45:15 PM]
[Jun 4, 2024, 4:43:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I was able to reproduce this issue by using the shortcut for Display in separate window / Display in main window menu items (Ctrl + Alt + Y) many times quickly. Andy, is it what you tried on your side?
I found it wasn't a memory leak issue, but rather a problem of synchronization between separate / not separate state of the 3D view. Anyway, I fixed it and the correction will be available in the next version.
[Jun 6, 2024, 11:23:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.D.STUDIO
Australia
@Puybaret, yes that is exactly what has been happening to me. Thank you for looking into it and I look forward to the update.
[Jun 6, 2024, 12:40:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Don’t expect an update too soon and meanwhile, avoid attaching / detaching the 3D view too quickly.
[Jun 6, 2024, 1:38:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.D.STUDIO
Australia
Would you consider releasing a beta or something for me to test? I'm not actually toggling that fast and have a presentation in a week.
[Jun 11, 2024, 2:36:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Is it so difficult to refrain yourself from toggling detached 3D view?!?
Or maybe your project is huge or it’s another issue.
[Edit 1 times, last edit by Puybaret at Jun 11, 2024, 3:54:47 PM]
[Jun 11, 2024, 3:38:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By the way, I noticed that the program didn't hang. If you click in the main window, it will activate it and you can continue to use it.
[Jun 11, 2024, 3:42:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A.D.STUDIO
Australia
OK well it hangs for me. Not sure why you'd offer detached 3D view if you don't think people should use it. I'm on a single screen, and because it can be done with a key command, I can go full screen 3D with a button press, and back again, which is actually quite convenient.
[Jun 12, 2024, 4:03:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
