Total posts in this thread: 12
Previous Thread This topic has been viewed 2110 times and has 11 replies Next Thread
jokergermany
Measure wall length
I want to measure the wall length of a curved wall.
How can I do this?
Thanks
[Jun 18, 2024, 3:58:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Re: Measure wall length
A workaround:
1. Connect the ends of the walls to close a perimeter;
2. Generate a room inside;
3. Use Rooms Information to get the perimeter;
Like this: (in meters)
4. Select the room and use Edit points from Advanced Editing plugin to find the length between start-end walls.
Subtract 1933 - 299.3 = 1633,7 cm
[Jun 21, 2024, 2:40:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jokergermany
Thanks will look at this when i am on my laptop.
(On the pc the old version which is coming from Ubuntu 22.04 is crashing with:
Java 3D: implicit antialiasing enabled
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
java: ../../src/xcb_io.c:278: poll_for_event: Zusicherung »!xcb_xlib_threads_sequence_lost« nicht erfüllt.
and in the online version i didn't found how to Generate a Room inside)
[Jun 21, 2024, 4:17:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
That's a very clever workaround! I could not think of a way to calculate it.
@jokergermany: note that this will give you the inner wall length, the length where the room touches the walls.
[Jun 21, 2024, 4:19:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captaincook
Même remarque que celle de Keet.
J'ai cherché aussi comment faire et voilà, Dorin est passé par là.
Super et merci à lui.
[Jun 21, 2024, 6:00:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jokergermany
Thanks for the hints.
A hint that this is a plugin would have been nice XD
@Keet
I know but better than nothing =)
[Jun 21, 2024, 6:03:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Outer lenght could be computed by generating the room using the autodimensioning plugin.
[Jun 23, 2024, 11:45:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captaincook
C'est vrai, Daniel, mais uniquement sur des murs rectilignes.
Pour les murs incurvés, l'auto dimensionnement donne uniquement les valeurs des rayons et des cotes environnantes de chaque bout de mur.
Mais pas leur longueur réelle.
[Edit 1 times, last edit by captaincook at Jun 24, 2024, 2:59:54 PM]
[Jun 24, 2024, 1:17:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@captaincook
You're right! But Daniels118 meant to say something else.
Autodimensionig could generate built surface:
The rest of the operations remain the same.
[Jun 24, 2024, 3:25:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
captaincook
Effectivement Dorin, vous avez encore raison.
Au passage, j'ai vu que j'avais la version V.1.5 du pluging Autodimensioning mais je n'ai pas trouvé où télécharger la V.1.6.
[Jun 24, 2024, 5:40:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
